Adobe Acrobat Pro DC 2023.003.2024 installation problem
Adobe Acrobat Pro DC 2024.001.20643 works fine with no problems to date. I get a message from Adobe when launched "Welcome to Acrobat"
Hello, I have a problem every time I want to run the setup I get this error message , anyone have the solution thanks
In step 1, to start the installation, instead of using the setup file, use the AcroPro.msi file
Good luck
Yobbo has the best ideas for dealing with Adobe. Keep in mind you are playing whack a mole with Adobe software and no install is going to be indefinite. I quit banging my head against the wall and sought out alternatives
Update.
Adobe caught me.
No doubt. This forum is full of bad luck stories with Adobe software. The thing is you give Adobe permissions to effectively use their programs even though you don't realize you have. They will find your cracked stuff unless you never go online, not just a firewall or hosts file block, no Internet connection period. I don't becuz I don't have a lick of their software including the PDF reader.
Phooey on Adobe. As soon as a cracking solution that works becomes available, Adobe is hard at work finding ways to defeat it. It's always been that way as far back as I can remember.
I have been monitoring an uploader for quite some time.
The name on torrents is "haxnode" I firmly believe he (not sure of gender) is uploading programs that were downloaded by others and then changes it to his name. I saw 2 comments on a torrent site about Adobe Acrobat 2024 pre-activated. I am quite sure he uploaded and changed to his name from FTUApps.
Here's a message I got from Bitdefender two times when I clicked on to view the 2 comments. I had to type a full stop . between hax and node.
"We blocked this dangerous page for your protection:
hax(.)node(.)net
Dangerous pages attempt to install software that can harm the device, gather personal information or operate without your consent."
I just installed Adobe Acrobat 2024.
Will keep you updated if Adobe wins again.
Hi guys, when trying to install Adobe, I'm getting this error, but when I go to the location, the intermediate.cab file is there. Any suggestions?
