website stat MICROSOFT Office PRO Plus 2016 | Page 11 | The Windows Forum
grimspecter said:
Please help. I'm trying to use the activator KMS Host service is installed, everything says successful but the key says its expired. i can't get the activator to work for me, the instructions don't really help me. In the textbox it says Activation failed with exception code 0x8000ffff. What does that mean?!
With mine, I found the copy of MSO was actually retail. I needed to run Convert MSO retail > VL and then do the activation. Did you run KMS as admin? :crazy:
KMS seems to be treating Windows 10 Pro x64 & MSO 2016 VL Plus as evaluation versions that are reactivated every so many days.
Hi all,
I successfully installed and activated MSO 2016 last September. Then after 9 months to the day, I got a notification saying that my activation failed. Has this happened to anyone else? I uninstalled, and then reinstalled and reactivated. I also used the advice in the post below. I am active again, with fingers crossed. I'll keep you posted as to how it goes.
- QD
ThumperTM said:
If you are having trouble installing this on windows 10 - it seems Microsoft is putting in checks to stop installations of pirated software. This is what I did to get it to work:
- change the name of the directories with your setup files so it doesn't contain anything about activation, version numbers etc.
-delete all readme files related to the torrent or crack
- move the crack out of the folder with the install files and into its own folder somewhere else.
My file structure looked like this:
C:Users[user]DownloadsMICROSOFT Office PRO Plus 2016setup.exe
C:Users[user]DownloadsOffice 2016 akvtrKMSAuto Net.exe
Notice none of the directories say anything about "activator" and the KMSAuto program is in a different directory.
Fix by tlike355
After 4 or 5 unsuccessful tries this is how I managed to do it:
System: Win 10 Home 64; No AV, AntiMalware etc. except Windows Defender
1 - Uninstall the previous, unsuccessful install. If you have other office related stuff in the list you see in the "uninstall or change a program" window uninstall them too.
2 - Restart your PC.
3 - Stay online but deactivate "real-time protection" from windows defender settings. (If you have other AV etc. deactivate them too)
4 - Create 3 new folders with random names.
Cut&paste "KMSautonet...exe" file into one of them and rename it, make sure its name doesn't resemble a crack-file's name.
Cut&paste all the read.me files into the second folder you've created.
Cut&paste all the other files into the third folder.
Delete the original folder.
5 - There are 3 different setup.exe files in the folder. Run setup64.exe (AS ADMINISTRATOR) if your system is 64bit .
6 - After the installation ends close the related window.
7 - Open Word by double-clicking on WINWORD.EXE which you can find here: C:\Program Files\Microsoft Office\root\Office16
8 - Just close or accept whatever window opens on Word's splash screen. Don't try to open a document.
9 - Close Word.
10 - Run the KMS activator file AS ADMINISTRATOR whose name you changed .
11 - If a warning pops up that says something like "Convert Office Retail -> VL" choose OK. Choose the related option in the following window that opens automatically; wait couple of seconds.
12 - Now you must see the KMS AutoNET2015 v1.3.8 main window. Click on "Activate Office".
13 - Wait like a minute or so until you see the auto-scrolling log stops. It finishes by a line telling the process was successful.
14 - Now you have to able to open Word without problems.
9 - Close Word.
Thank you for taking time to write this post ;)
Have no idea how to install this. The readme is not helpful at all...which installer should I use? How to activate it?
i downloaded this today and it seems to be working but it downloaded everything. first off, i was wondering if there is any way to convert it to the retail version
and 2 is there a way to only install certain ones. i only need word, and pp, and excel
SNDP333 said:
Hey, what is patch file.? with what name it is saved ??? Iam getting message/error to activate. Please help.! Thanks in advance.
I have the same problem, please anaybody can help?
Thanks!
it was working for me for a month and now its suddenly stopped. i've read tru all these pages, none of the solutions worked for me.
i dunno how to fix this?
i tried ALL of these :S
P.S.Its back to "product activation failed"
please send me the product key for microsoft office pro plus 2016 v16.0 4266.1003 RTM Activator.
I would really appreciate it. Thanks.
Please send me the product key MICROSOFT Office PRO Plus 2016 v16.0.4266.1003 RTM + Activator
ok, i just joined because Ive got the MS Office Pro 2016 installed and working but it says activate before 28-Aug-2017. what is the cracked key to activate it?
