- Aug 18, 2010
Well, if you are here to clarify instructions...
1. Extract what archive?
2. Rename what folder? (Is this necessary?)
3. By setup do you mean 'Acrobat_DC_Web_WWMUI '?
4. By update file do you mean 'AcrobatDCUpd1901020098'?
5. The "Activation" is a zipped file, that includes two more zipped files. Do I then unzip those two? You stated to "use activator", which is very broad when considering there are two zipped files within in a zipped file.
6. This seems more confusing than it should.![]()
Its super easy, if it looks more confusing than it should, feel free to buy it directly from adobe website.
Topic closed
