ok, for starters, what is the installation directory
Right click software icon, go to "Open file location", thats installation directory.
I have also tried to install version 2019.010.20098 with the adobe.snr.patch.v2.0-painter patch.
Same problem as others here, it just asked me to login, or it stops automatically. Seems it doesn't work.
Installed it on a fress W10 install. Perhaps it works if I hadn't installed Adobe Reader?
Your reply is SO FUNNY!!!Its super easy, if it looks more confusing than it should, feel free to buy it directly from adobe website.
Topic closed![]()
Do a search for it at a torrent index site, 1337x for example.So, where is the link of the torrent?
That one that currently sails the bay seems to be using a very old, very complex solution. IF you haven't and don't plan to download and use any Adobe products made in the last couple of years it might be worth a try. Let us know if it floats or sinks. I wouldn't even guess based on what we have been hearing.Hi dears, I have problem installing the "AcrobatDCUpd1901020098.msp" from Adobe acrobat pro dc.
The message pops up like this:" the upgrade patch cant be installed by the windows installer service because the programm to be upgraded maybe missing or the update patch may update a different version of the programm to be upgraded exists on your computer and that your have the correct upgrade patch".
Hello Guys,
So I downloaded your software from Torrent and I tried to install it as per the instructions but unfortunately it's not working. I'd some screenshots and if anyone of you can have a look into them and tell me what I'm doing wrong I'll be really thankful.
So after Installing Both the Adobe Acrobat and The Updated one I'd Extracted the Activation.rar and it looks something like this:
After this I copy pasted everything from the extraction into the Installation directory: (I'd selected/highlighted the files that I copy pasted)
After this I run adobe.snr.patch.v2.o as an administrator and it came up with something like this: (the thing to note here is that it has nothing with the name of Adobe Acrobat DC 2019 and there's only one file that's with the name of Adobe Acrobat DC 2015 and that too is 32bit and my machine is 64bit but I selected it coz that's the only one available)
After this I clicked on patch and it showed "OK" for everything. Also during all this my antivirus and internet was turned off. And when I opened Adobe Acrobat DC the window popped up like this:
Can anyone tell me what I'm doing wrong or guide me to the correct steps? I'd really appreciate that. Thanks in advance and also thank you ThumperDC for creating a crack. I might not be able to access it for now but there are many people that are using it.
I have 2 questions and please don't take offence to either.
1) I am trying to install this software on a work computer in which admin rights belong to the IT department. Is there any way around this? Currently it doesn't allow me to modify the install directory files.
2) The instructions in the read me files are always simple, but not detailed enough to address specific questions that arise. Would it not be easier to create a video tutorial for the install so that we can see specifically how it you have done it. Seems this would reduce the amount of time answer questions on these forums.
Thanks for the software and thanks for considering my suggestion.
Could you help in pointing me to the download link for the Adobe Acrobat (final version)? i cant seem to find it, and went all over the forum. many thanksHi,
Please send me PM with link and i will reply.
Thank you!
