website stat Windows 10 - Adobe Acrobat PRO DC 2020.009.20063 | Page 4 | The Windows Forum
Windows 10 Adobe Acrobat PRO DC 2020.009.20063
ok whatever, DC 2020 is very pesky, unless someone finds where the fuck the residue remains with the login stuff we can just use DC 2015 which crack works perfectly fine
Hi, it worked for me with AcrobatDCUpd2000620042 only. Moreover, I can confirm that there is no need to do a clean install of Windows 10. You just need to uninstall previous Acrobat version (through Control Panel), delete all Adobe folders in %USERNAME%\AppData and in %COMMONPROGRAMFILES(x86)%, restart PC and follow the instructions provided here https://thewindowsforum.com/threads/adobe-acrobat-pro-dc-2020-009-20063.81109/#post-117218 , but don't forget to skip AcrobatDCUpd2000920063 and use AcrobatDCUpd2000620042 instead.
Bear in mind: Newer versions don't work. I tried AcrobatDCUpd2000920063 and AcrobatDCUpd2000920067. No success!
I have the same problem. I actually installed the downgrade to this version: v2020.006.20042 and it didnt work.
Please find attached, Installation Instructions:
NOTE: You must downgrade to this version: v2020.006.20042 (version 2020.009.20063 won't work with below notes, sorry)
v2020.006.20042 - Tested and working :)
Hi!
This did not work for me. However, I featured out a different approach.
Instead of Step 8 and 9 in "Installation Instructions Acrobat.txt" follow this:
  • Copy “adobe.snr.patch.v2.0-painter.exe” to install location. Install location by default is C:\Program Files (x86)\Adobe\Acrobat DC\Acrobat
  • Run as Administrator "adobe.snr.patch.v2.0-painter.exe"
  • Select "Try to patch another product with the amtlib file (32-bit)"
This method works with version 2020.009.20063. The sign-in box should not appear anymore.
Try the method I provided for newer versions.
Hi
Unfortunately, this also did not work for me. So, decided to install Adobe Acobat XI Pro. Success
I have the same problem like amincom
Any ideas? (Quote doesnt work?)
Try this:
Hi!
View attachment 5304 View attachment 5305
hi
i cant install 6) Install "AcrobatDCUpd2000920063.msp"
You mean AcrobatDCUpd2000920063.msp is not working?
  • First ensure that Acrobat DC is properly installed.
  • If Acrobat DC is installed and AcrobatDCUpd2000920063.msp is not working try to update online.
  • After updating restart your PC and disable your internet connection and antivirus.
  • Continue with the steps that come after installing AcrobatDCUpd2000920063.msp.
  • And use this method
Hi!
where the file for the v2020.006.20042?
Hi Thumper TM - tried ur Adobe Acrobat PRO DC 2020.009.20063 with much hope but sign in box wudnt allow to move past - tried all tricks so now thinking of downgrading to v2020.006.20042 - but I cudnt find that file even- the only thing I see is Pro.DC.2020.006.20042.Preattivato.Multi - which has its own instrcutions- so I guess I'll go with that and ur instrcutions...lemme know if there;s something else.!!
I managed to make version 2020.009.20063 to work also with a different approach.
After following the instructions by ThumperTM from this post:
I backed up somewhere the patched amtlib.dll file from version 2020.006.20042
Usual location is at: C:\Program Files (x86)\Adobe\Acrobat DC\Acrobat\amtlib.dll
After, i upgraded to version 2020.009.20063 and then i copied back the backup file i made in the previous step.
Acrobat is now running on the latest version with no Sign-in screens :cool:
Try to downgrade with the official (Version 2020.006.20042) update file from Adobe:
https://supportdownloads.adobe.com/product.jsp?product=1&platform=Windows
Really...can I downgrade to 0042 even if I've installed 0063.....just using this file as a patch?
Running 'Adobe Acrobat PRO DC 2020.009.20063' using updated instructions with no issues!
Thank you! :D
so u first installed 0063, then downgraded to 0042 using these "https://thewindowsforum.com/threads/adobe-acrobat-pro-dc-2020-009-20063.81109/#post-117218 and then how did u get back to 0063 ?
There're a bunch of tweaks that ppl have tried in posts above - not sure what's the correct sequence
...wud be good if someone posts a modified steps version that worked for 0063 being latest.
