website stat MICROSOFT Office PRO Plus 2016 | Page 6 | The Windows Forum
Hi. Validation is not complete for me and i am getting this page when verifying http://prntscr.com/duo3qm . I use windows 10 but i assume this is supposed to work for windows 10? Am i doing something wrong says it is working here http://prntscr.com/duo3i2 Cheers.
Which file do I run first to install?
The Setupfile? Or one of the 34 or 64 files?
Then what do I do?
Hi thumper. did you see my post above. Do you know what the problem is? Thanks for your help.
I downloaded the MICROSOFT Office PRO Plus 2016 v16.0.4266.1003
First thing i run the set up as administrator but always end up showing error code 30180-4 (please make sure you're connected to the internet then try again).
I turned off Avira Antivirus and windows firewall but still cant get it to install and the same error message appears again and again.
I have a good internet connection.
Please help.
adiltwahir said:
Please help.
Rename folder to something shorter like office or 2016 and try again.
Dear ThumperTm,
I have Windows 7 ultimate edition, I followed the steps and faced certain issues with "Internet settings errors" , folder length etc... but this forum and google helped me to fix those issue, and finally Product is activated using activator provided in the package, Heartiest thanks to you keep doing the good work...cheers
Although I have a small query in "Account tab" in word I can see the product is activated to my curiosity I wanted to check the expiry period and other info using cmd.exe. I did ... C:\... \Office16>cscript ospp.vbs /dstatus but processing failed, it did not returned any result may be I may have missed something...
But Thanks a ton again!!!!
Kind Regards,
Gaurav
ThumperTM said:
adiltwahir said:
Please help.
thanks this worked :danca:
Hi. Do we / should we remove older versions first ? Or can it be done after?
What do you suggest///?
Thanks
Hello there
I installed the program. I also ran the activation file by clicking on the office button.
When I open the office, says "You have to activate it."
What have I done wrong?
Hi. I have posted twice in this forum but i seem to be getting ignored. Could you at least tell me why my posts are being ignored? my office demo run out today and i can no longer work the software properly. Would really appreciate some help. below is a copy of one previous post.
ThumperTM said:
luxmo said:
ThumperTM said:
If you are having trouble installing this on windows 10 - it seems Microsoft is putting in checks to stop installations of pirated software. This is what I did to get it to work:
- change the name of the directories with your setup files so it doesn't contain anything about activation, version numbers etc.
-delete all readme files related to the torrent or crack
- move the crack out of the folder with the install files and into its own folder somewhere else.
My file structure looked like this:
C:Users[user]DownloadsMICROSOFT Office PRO Plus 2016setup.exe
C:Users[user]DownloadsOffice 2016 akvtrKMSAuto Net.exe
Notice none of the directories say anything about "activator" and the KMSAuto program is in a different directory.
Fix by tlike355
Thanks, It worked for me. You saved my day.
Good to hear it. :D
this worked for me as well
i also had to reinstall everything and eventually i had to keep patching it until a window popped up about retail 2016 for Microsoft and some key converter. Ik this is kinda wont help but I hope someone understands this and can elaborate
Hi I have installed Microsoft office Pro 2016. Everything worked at first but at 10 days, Outlook fails to load. All other programs(word, excel etc) work fine but not Outlook. Please can you help. :D
hey, quick question, is the version you uploaded 32 or 64 bits? This one: https://1337x.to/torrent/1300529/MICROSOFT-Office-PRO-Plus-2016-v16-0-4266-1003-RTM-Activator-TechTools/
