WingedDevil1910
- Dec 8, 2016
Can someone please help me? I downloaded the file as per instructions but I can't seem to find the patch file to run it? Help please! T_T
Thanks, It worked for me. You saved my day.ThumperTM said:If you are having trouble installing this on windows 10 - it seems Microsoft is putting in checks to stop installations of pirated software. This is what I did to get it to work:
- change the name of the directories with your setup files so it doesn't contain anything about activation, version numbers etc.
-delete all readme files related to the torrent or crack
- move the crack out of the folder with the install files and into its own folder somewhere else.
My file structure looked like this:
C:Users[user]DownloadsMICROSOFT Office PRO Plus 2016setup.exe
C:Users[user]DownloadsOffice 2016 akvtrKMSAuto Net.exe
Notice none of the directories say anything about "activator" and the KMSAuto program is in a different directory.
Fix by tlike355
luxmo said:Thanks, It worked for me. You saved my day.ThumperTM said:If you are having trouble installing this on windows 10 - it seems Microsoft is putting in checks to stop installations of pirated software. This is what I did to get it to work:
Fix by tlike355
Adhal fazal said:can anyone help how to download it
Beidniz said:Hi, when I opened the main file, or "unpacked" it, the folder seemed to be empty. I may have done something wrong here?
</e></QUOTE>toddwebguy said:</s>I know that there is a thread for this, but I couldn't post in it. Here is my issue. Hi. I just came across this file, and don't know how to set it up. i have kms auto net, an autorun file, the 32 and 64 set up files for office, and another file that says set up. the read first says'... Install application using provided installer and do not reboot<br/>
3) Run patch file<br/>
DONE!<br/>
<br/>
I don't know what the provided installer is. or how to run a patch. sorry for being a newb. thanks in advance<br/>
<br/>
Todd<e>
fewwork said:I don't understand the (Stop the application if started
ur2b said:went through the read me and was a little unclear.... the download went fine and really fast, but im not sure how to install. the installation file shows up as opening with utorrent, and wont actually install itself.... i've tried everything i know but im not sure what else to do.
